48 Users Online (46 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Community >> Newbies >> making in-place mass solid/"real"?
Mon, Aug 22, 2011 at 5:56:08 AM | making in-place mass solid/"real"?
SGotthard
Hi,
I have an issue that might be very easy and obvious to you, or maybe I've misunderstood the concept of in-place mass and then it won't be solved. Anyhow, I have made an in-place mass that is supposed to be a sketch on 6 doors in a custom made cabinet (i'll attach an image).
My problem is that, as they are now, they aren't of any material, meaning they are see-through and won't render, for example. Properties isn't giving me anything to change and using the "add wall/floor/curtain wall"-option is not what i am after. So, is there anyway to just "fill" these transparent shapes with a material?
Thanks in advance
// Simon
Mon, Aug 22, 2011 at 6:42:46 AM | making in-place mass solid/"real"?
Why did you use a mass when it is a cabinet?
If you want an in-place family, then do that and make it be the right category.  Then, as you create the solids, assign a material to them.
Mon, Aug 22, 2011 at 7:40:06 AM | making in-place mass solid/"real"?
AbsoluteBIM
AbsoluteBIM Avatar
4 Stars: 4 Votes
See attached image, you should have modeled this as an in-place component not a mass.
Mon, Aug 22, 2011 at 8:04:16 AM | making in-place mass solid/"real"?
SGotthard
Managed to figure it out eventually and created a new family with material parameters.
Good advice, thank you!
Tue, Nov 22, 2011 at 7:54:14 AM | making in-place mass solid/"real"?
AlphaOjo
I'm having a similar issue.  I used in-place masses to represent buildings around my site, but now I realize that I want them to show all the time and apply materials to them.  Is it possible to convert them to generic model families or something else without having to recreate them all as in-place families? ?
Tue, Nov 22, 2011 at 12:40:26 PM | making in-place mass solid/"real"?
4 Stars: 203 Votes
Sorry but you can't, changing to or from the mass category is prohibite, but you can apply a different material to each solid (mass) you have in your project.
Edited on: Tue, Nov 22, 2011 at 1:31:47 PM
Sweeping Solid In-Place Mass
Tue, Apr 27, 2010 at 3:30:39 AM
Making an object from solid mass...
Mon, Oct 25, 2010 at 7:17:07 AM
Making a Solid Sweep in 2010
Thu, Oct 22, 2009 at 9:41:13 AM
How to make a "Model in-place" a "Family"
Thu, Mar 17, 2011 at 5:08:00 PM
Editing Mass Elements
Wed, Nov 4, 2009 at 12:29:07 PM
Page generation time: 1.7764
