49 Users Online (46 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Brick veneer walls have 'unwrapped' at corners
Sun, Aug 21, 2011 at 1:36:32 AM | Brick veneer walls have 'unwrapped' at corners
JohnB1960
While modifying a completed model with brick veneer walls the previously well behaved walls have 'unwrapped' at all external corners - and I can't find why.They still look fine in all 3D views and render as before, but in the floorplan the frame and cavity run to the exterior surface. The unmodified detached garage made from the exact same wall type has remained wrapped as normal.
Any hints on what I've accidentally clicked to make this happen??
John
Sun, Aug 21, 2011 at 1:39:14 AM | Brick veneer walls have 'unwrapped' at corners
JohnB1960
Sorry, forgot to mention - this is on the latest update version of 2012.
Sun, Aug 21, 2011 at 2:13:00 AM | Brick veneer walls have 'unwrapped' at corners
JohnB1960
OOOOPPS - I was mistaking normal corner cleanup with wrapping - all fixed.
Brick veneer stepping at alternate elevations
Wed, Aug 14, 2013 at 8:28:36 PM
Partial Vertical Reveals in Vertically Compound Walls
Thu, Jul 24, 2008 at 1:04:53 PM
BRICK VENEER WALL
Fri, Jul 22, 2005 at 8:55:04 AM
''Visibility grafics'' and ''create parts'' problem when mak
Fri, Mar 19, 2021 at 11:45:46 AM
230 brick wall wont cleanup to 250 brick veneer wall (images attached) RA2008
Wed, Sep 3, 2008 at 12:33:09 AM
Page generation time: 0.9065
