23 Users Online (21 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Print Order
Sat, Aug 20, 2011 at 10:39:43 PM | Print Order
Pdoak
I have a simple set of drawings to print. Cover page ("C-Cover Sheet"), A1-A3. I need to print them all to a single PDF file, but the problem is, when I go to print: I select the "print to single file" option for my cute PDF printer, but when I choose the list of sheets to print, they are all arranged in alphabetical order, so what I get is A1-A3 then the cover page. Is there a way to customize the order? I have been able to align them properly in the project browser by setting up a project parameter called "Index" and assigning a numeric value to the cover sheet equal to 1, and then A1 is assigned 2, etc...
Thank you!
Sun, Aug 21, 2011 at 8:32:21 AM | Print Order
You will probably have to re-order them in a different program.  A different PDF print program might also work.  We use cutepdf and it does the same thing.
Wed, Nov 21, 2012 at 1:51:49 PM | Print Order
EnvDrafting
It's not your PDF, ist Revit... Has anyone found away to re-order the Sheets in the print set? I'd like to know this too. Whether sent to a PDF writer, or a plotter, it's the same problem.
Wed, Nov 21, 2012 at 1:53:17 PM | Print Order
There is no method of doing this from within Revit.... natively
Use something like Chris Price's (Cadway) add on to manage your output.
Edited on: Wed, Nov 21, 2012 at 1:54:26 PM
Wed, Nov 21, 2012 at 2:17:42 PM | Print Order
Pdoak
I worked around this by renaming my sheets so that the cover page was "A0". If you have several groups, such as Arch, Mech, Struct, and Elec, I think you can group them and assign them in saved sets under the publish option (or print? don't have Revit on the computer I'm posting this from, so can't check, sorry). So when you go to publish (or print) you can choose a preset list of sheets, defined by you, from a dropdown list to publish/print. There are free programs (or trials, think I've used nitroPDF or something) you can get to rearrange or parse the sheets you don't want from the set you print, or print your sheet sets separately to PDF and combine.
hide ellements when you want to print,BIM gets in the way
Thu, Aug 28, 2008 at 10:51:06 AM
Electrical shows up in plan view, but will not print.. Help!
Mon, Jul 21, 2014 at 3:04:36 PM
draw order in revit 2010
Tue, Sep 23, 2014 at 1:24:32 PM
Revit views to DWF format to print
Fri, Mar 19, 2010 at 12:21:42 PM
Plot Order
Tue, Jan 3, 2012 at 9:40:19 AM
Page generation time: 0.4202
