46 Users Online (45 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> best way to align a curtain system across many faces of a mass?
Fri, Aug 19, 2011 at 12:29:51 PM | best way to align a curtain system across many faces of a mass?
d3athcarb4fatty
Hi, I have a somewhat complex mass that I have imported from Rhino that I am trying to develop a curtain system on in Revit.  I noticed that I can select the individual faces of the entire curtain system from the mass and change the angle of the grid, but is there a more precise and less tedious way of getting a grid to space consistently across many faces?  Or, should I try to model this instead with curtain walls within Revit?  In that case, what would the best strategy be?
This is actually an existing building (saxo bank by 3xn) that I'm modelling as a case study / to learn Revit better.
Thanks!
Wed, Sep 5, 2012 at 8:33:07 AM | best way to align a curtain system across many faces of a mass?
stealthnyc
4.5 Stars: 2 Votes
Sorry for the late reply but I don't think you can align grids with the align tool but you can set an offset to the grids in the curtain system instance properties
Curtain System from Mass - Mullion Joins
Fri, Dec 11, 2015 at 7:27:44 PM
Revit 2017
Fri, Jun 17, 2016 at 2:53:58 PM
Curtain system from mass - Revit 2014
Fri, Jun 17, 2016 at 12:20:49 PM
Advice on Curtain Systems and Slabs from Mass
Tue, May 10, 2016 at 12:17:57 PM
CADclip - Curtain System by Lines in REVIT Architecture 2010
Thu, Feb 18, 2010 at 6:29:53 PM
Page generation time: 2.8399
