98 Users Online (97 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Levels hidden in elevation
Thu, Aug 18, 2011 at 1:15:46 PM | Levels hidden in elevation
jwalexa
I'm running into this problem with my levels not showing up in elevation.  The level is there, when I hover over the area that level is supposed to be with my mouse, it shows up highlighted.  Even when I click on it, it displays.  But when i move the mouse the level is hidden.  I checked the vg and everything is all good.  I have other levels that show up but not certain ones.  I've also tried the cropped region thing that others suggested and even unchecked the far clip active box that other suggested also.  I'm running out of ideas on how to solve the problem.  Can anyone please help me
Thu, Aug 18, 2011 at 2:29:17 PM | Levels hidden in elevation
AbsoluteBIM
AbsoluteBIM Avatar
4 Stars: 4 Votes
I seem to 'loose' my levels quite often. I find that usually my level lines don't extend far enough in one direction to show up in the elevation. The level lines need to be cut by the elevation box to appear. try cutting a new section right through the building, this should show all your levels, and then drag the level line WAY over. Then just delete the section view you created. I hope this helps.
Levels are missing - I tried all solutions on forums no result
Wed, Jan 30, 2013 at 10:57:43 AM
Elevation Levels Mess
Thu, Jun 26, 2008 at 11:53:13 AM
Levels missing Revit 2012 [ 1 2 ]
Mon, Sep 28, 2015 at 3:29:41 PM
19
Cannot see my floor levels
Tue, Mar 10, 2015 at 12:42:26 PM
Showing objects in higher levels in hidden linetype
Tue, Feb 21, 2012 at 7:10:07 AM
Page generation time: 0.9733
