37 Users Online (35 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Best way of creating column casings
Thu, Aug 18, 2011 at 9:35:05 AM | Best way of creating column casings
archie456
3 Stars: 1 Votes
Hi,
In our building the steel columns will be cased in 2 layers of plasterboard, which is the same finish as the partition walls.
The engineer has produce a model of the steelwork, I've used rectangular architectural columns which 'warp' the plasterboard wall surface around the column - this works great.
The problem I have is where a column is not against a wall, its in the middle of the room - when I use an Architectural Column its has no surface to attach to, and so does not show two layers of plasterboard.
Whats the best way of casing independant columns?
Thanks.
Thu, Aug 18, 2011 at 11:23:37 AM | Best way of creating column casings
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
draw a wall around them, if columns are rectangular, then include nailer, if columns are wide flange then use two different walls one with nailer, one just drywall.
Fri, Aug 19, 2011 at 2:17:13 AM | Best way of creating column casings
archie456
3 Stars: 1 Votes
Yea - we though of doing that, I just wondered if there was a 'clever' way of doing this, like the way architectural columns work.
I guess not then.
Thanks for your reply.
Creating Columns
Tue, Sep 6, 2011 at 2:56:34 PM
Tagging Graphical Column Schedule
Wed, Nov 24, 2010 at 8:41:15 PM
Column Schedule
Mon, Apr 21, 2008 at 7:35:30 AM
Column base plate tag units display.
Mon, Nov 17, 2014 at 2:24:41 PM
creating column based with carvings
Wed, Oct 5, 2005 at 6:01:30 PM
Page generation time: 0.6414
