84 Users Online (82 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Unit Tolerances
Tue, Aug 16, 2011 at 1:27:56 PM | Unit Tolerances
ALICEHER
Hi,
I was wondering if there was a way to set up my project dimensions (not my dimension strings) to something other than 1/256". I find it very frustrating when I dimension something and it's 1/64" off. I try to be as accurate as I can, but I always seem to come across a weird dimension. Is there a way I can set up a 1/16" grid so my walls, lines, etc. will always snap to the 1/16"? I am using Revit 2012.
Thank you.
Tue, Aug 16, 2011 at 2:14:12 PM | Unit Tolerances
You can set up your snaps so that when you add elements, they will snap relative to other items.... but that will not get rid of your problems.  You need to pay attention to temporary dimensions and change them as you are adding elements.  Weid dimensions may still happen in the end, depending on the families used but if you are careful in your modeling, those will go away.  Keep your project units to 1/256 but for final architectural dimensioning, the rouding might be best at 1/8
Tue, Aug 16, 2011 at 3:30:25 PM | Unit Tolerances
ALICEHER
Thank you so much for your quick response.
Multi Unit buildings
Mon, Jun 6, 2005 at 2:41:01 AM
Can a Linked file be tagged in a host project to indicate the unit Type?
Sat, May 15, 2021 at 4:12:22 AM
Unit tolerance
Thu, Jan 21, 2010 at 5:12:11 PM
Door/Window tag to not display unit symbol?
Thu, Aug 18, 2011 at 3:44:55 PM
Schedules - Grouping by Unit
Tue, Nov 21, 2006 at 5:51:56 PM
Page generation time: 0.2901
