61 Users Online (60 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Blank mark door tags for unit plans
Tue, Aug 16, 2011 at 11:40:36 AM | Blank mark door tags for unit plans
Kartyh2
I am working on a project that has multiple units "apartment" plans with the same layout. I want to utilize the door mark to label doors in the common areas. Then leave the door mark blank in the unit plans. Distinuguishing these with the door type mark. Is ther going to be problems down the road with multiple blank door marks. I know that if you have the same value you get warning but I received no warning when blank.
Area and Room Tags
Thu, Apr 16, 2009 at 2:48:06 PM
Using Area Plans as Main Floor and Unit Layout plans
Mon, Mar 29, 2021 at 1:59:33 PM
Door/Window tag to not display unit symbol?
Thu, Aug 18, 2011 at 3:44:54 PM
? in tags with blank values
Wed, Jul 29, 2015 at 9:17:23 AM
room tag blank field
Tue, Sep 25, 2007 at 8:33:16 PM
Page generation time: 0.5363
