64 Users Online (63 Members):
Forums >> Community >> Newbies >> Stringer Haunch (level off) at top of flight
8 Posts No Rating |
I know that I have been able to do it before but I can't seem to figure out why it does this. I am trying to extend the top of the stringer a distance of "X" but it thinks of it as another riser and slopes the stringer to the end of the extension. I have the "end with riser" unchecked and I split the stringer lines 2" from the nosing. All I am wanting to do is have it go straight out from the nosing. i am working on a 20 flight stair and many of them require this condition. and I need the full 12" stringer profile to extend as well. I can always just model-in-place a stringer but I think it looks better to be part of the flight.
8 Posts No Rating |
Nevermind. I extended the "run" line and it worked for me.
19 Posts No Rating |
I am having this problem too but when I try to extend my run line to my top landing it just creates more treads where my landing was. (My staircase is not a scissor stair) I attached images. Thanks!
@durangoarchichick Second image: the line on the far right is a riser line, make it a boundary line.
http://www.turbosquid.com/Search/Artists/Revitaoist |
Rod,
I tried that but this message pops up: "Stairs require no less than two boundaries (chains of one or more Boundary Lines)." Then it won't let me finish sketching.
You don't want to use a landing here. I know, it is one!.
The problem is that with these type of stairs, the stringer will go along all sides of the landing and you don't want that across your opening. We use a floor here and add the channels along the two sides.
Hm, Ok very interesting. Thanks, I'll see what I can do.
Delete the last "Riser" then create the "Floor" like WWhub said and the "Stringers" will be ok.
Ah ha, Thanks.
Stair Editing |
Mon, Feb 24, 2014 at 2:09:28 PM
Modelling stairs and balustrades by level. |
Thu, Dec 8, 2011 at 2:44:27 AM
Need Help on Stringer |
Fri, Jul 10, 2015 at 7:24:07 AM
How to create a double landing stair (one top and btm) |
Tue, Nov 1, 2011 at 7:47:28 AM
Concrete Beam Family with a Haunch |
Wed, Sep 1, 2010 at 3:03:15 PM
Members: | 2017185 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
