156 Users Online (154 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Community >> Newbies >> Model Line constraints in family editor
Mon, Aug 15, 2011 at 11:15:11 AM | Model Line constraints in family editor
dsmelcer1234
Total newb here, still in evaluation mode. I am trying to create a craftsman style column family. Running up the edges is a 1x4 trim board but i rather would use a model line to cut down on geometry. It seems revit is using "smart constraints" to keep the model lines in the right place I guess, because they are moving correctly when I flex the column, except one of the model lines is not moving corectly. I am not sure what revit is using to constrain the model line to. Any help would be appreciated.
Mon, Aug 15, 2011 at 11:46:26 AM | Model Line constraints in family editor
Control lines at angles in Revit families is hard to learn.  I suggest you download the families guide from the autodesk site.  They have something similar in controlling a door swing and that should give you some ideas.  I'm not sure how you built your family, but I doubt you saved much in overhead.  I would do this tapered part of the column as a blend and it would be very easy to control.  For reference planes in plan would control the shape.
How the heck can I get line styles to Families?
Mon, Apr 14, 2014 at 11:21:59 AM
Plan in Revit Family Editor Differs from Plan in Model
Tue, Nov 14, 2017 at 2:18:11 PM
Draw Order in Family Editor
Wed, Aug 28, 2013 at 3:07:32 PM
general windows parameters and constraints help
Wed, Oct 29, 2008 at 12:11:46 AM
14
Family Editor: works... then doesn't!
Fri, Sep 2, 2005 at 5:23:06 PM
Page generation time: 5.7503
