Forums >> Revit Building >> Technical Support >> Decals not rendering
9 Posts No Rating |
Revit 2011
I have placed decals and they don't show up in render. Some other suggestions mention a path. When I go there and check, there isn't anything listed. When I go to my desktop to add the images, they aren't listed for me to shoose. Also, they are applied to a split face. Any suggestions?
Thanks
"Also, they are applied to a split face. Any suggestions?" - That's the problem, the "Split Face", when you split the wall, the decal could not host across the split.
Look at the bottom of this page and you will see similar threads about this same issue.
9 Posts No Rating |
Ok, so I deleted the split face and the decal still doesn't show up in render. However, the box is there indicating that it should be. It is also not on the wrong face, already checked that too. I'll attempt to upload a couple of screen shots with descriptions of my problems.
9 Posts No Rating |
Apparently I can't figure out why my images are not attaching here...
9 Posts No Rating |
And trying again...
9 Posts No Rating |
Is there something wrong with the file attachment option for the forum posts? I'v tried a few times and they aren't uploading...
Edited on: Wed, Aug 17, 2011 at 10:11:57 AM
Your problem is the browser you are using. RC does not support chrome or the latest mozilla.
9 Posts No Rating |
I'm using explorer
9 Posts No Rating |
I figured out the decal problem. I guess there can't be a split face ANYWHERE on that wall, even if it's not where you are applying the decal. My solution- I just made a 1/2" generic wall and placed it between my "real" wall and the decal.
problem with rendering decals |
Mon, May 14, 2007 at 5:44:58 PM
Decals not Rendering in 2010/12 |
Wed, Jul 20, 2011 at 1:34:54 PM
problem rendering decals |
Tue, Aug 3, 2010 at 8:18:17 AM
Rendering Decals |
Fri, May 8, 2009 at 11:45:12 AM
Decals not showing.. |
Fri, Feb 16, 2018 at 9:39:05 AM
12
Members: | 2102386 | Objects: | 23173 | Forum Posts: | 152296 | Job Listings: | 3 |
