27 Users Online (24 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Ceilings not showing
Fri, Aug 12, 2011 at 1:20:34 PM | Ceilings not showing
cc4927
Hi I have ceilings throughout my plan.  They show in section, in 3d and in elevation.  However they don't show in my RCP...it is not allowing me to place lights on the RCP except in one room.  I sketched the ceiling in each room.  Ceilings are on under VG.  When I highlight the area and do filter they do not appear.  However if I look at my 3d view they are there...PLEASE HELP...I can't figure it out!!  Thanks!!
Fri, Aug 12, 2011 at 2:06:47 PM | Ceilings not showing
How did you do your reflected ceiling plans?  They are not a floor plan.
Also check VG and phases.
Fri, Aug 12, 2011 at 7:06:04 PM | Ceilings not showing
cc4927
Thanks...the ceilings were created on the Ceiling Plan option...and they are showing in VG..still can't figure it out
Fri, Aug 12, 2011 at 9:10:52 PM | Ceilings not showing
renderforfun
4.5 Stars: 6 Votes
what height do you have your ceiling at? If your cut plane is not set up correctly in that ceiling plan you will not see it.
1st - What is ceiling height?
2nd- Go to ceiling plan and tell me what you have for a value in all the boxes under your View range tab. Cick on the ceiling plan then type in VP and scroll down till you see view range.
With this information we should hopefully be able to resolve the problem. Good luck.
Ceiling diffusers not showing up in ceilings when combined with architecturals
Wed, Sep 2, 2009 at 5:20:10 PM
Model In Place Ceilings Not Scheduling??
Wed, Jan 15, 2014 at 10:55:35 AM
Ceilings Not Showing In Elevation/Section
Thu, Oct 1, 2015 at 7:31:33 AM
Complex ceilings
Thu, Oct 8, 2015 at 1:02:54 PM
Existing Phase / Ceilings solid gray
Mon, Oct 15, 2012 at 12:40:18 PM
Page generation time: 2.4603
