46 Users Online (45 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Auditorium Floor
Wed, Aug 10, 2011 at 11:35:48 AM | Auditorium Floor
billp
Can anyone tell me the best way to create sloping floor for auditorium with a 6 degree slope and curved at the top & bottom
Wed, Aug 10, 2011 at 11:43:48 AM | Auditorium Floor
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
It would help if you had a view of the plan and what you want to do, a sweep or a sweep blend or several different ones is likely.
Wed, Aug 10, 2011 at 12:53:28 PM | Auditorium Floor
billp
Here a plan view of auditorium
Wed, Aug 10, 2011 at 4:19:51 PM | Auditorium Floor
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
Ok, so see the attached method for doing sweep blend, I would set up your sweeps which probably can be only sweeps, not sweep blends as you will be dealing with constant elevations I think. I would set them up as radials sort of like the street work see attached and I would do 3 different sweeps which you can mirror around the centerline. Hope this helps.
Auditorium Floor Multiple Slopes
Fri, Feb 22, 2008 at 12:31:25 PM
auditorium seats lack elevation adjustment
Sat, Jul 23, 2005 at 11:07:10 PM
auditorium seat family and sloped floor
Tue, Dec 8, 2009 at 9:54:25 AM
Move Portion of Project to New Levels
Wed, Jan 7, 2015 at 11:06:06 AM
Auditorium/Theatre floor?
Sat, Feb 9, 2008 at 7:55:47 AM
Page generation time: 1.6030
