60 Users Online (59 Members):
Forums >> Revit Building >> Technical Support >> WIDE LINES
In AUTOCAD we used the polyline (dashed) function to indicate the boundary on the site plan, when using Revit is there a similar command where you can create a very thick line, ive tried the detail wide line but it is far to thin for what i need, any help be much appreciated,
Thanks in advance
Will
look under settings- line style - create a new line, call it prop line ( or whatever) then give it a high number (thickness) then it will be available to use as a line.
?? Why aren't you using actual properties lines for the boundaries?
To have the thick line just change the property line object style.
How to add lineweights to Revit…Instead of the default wide, thin, hidden, e |
Mon, Oct 1, 2007 at 10:44:47 AM
titltblocks |
Fri, Jan 16, 2004 at 2:43:31 PM
Is Autodesk Revit wide screen compatible |
Wed, Mar 28, 2007 at 6:12:31 PM
How to create Roof Sheeting profile 28 metres wide |
Thu, Apr 23, 2009 at 8:36:26 PM
Line Work Problem |
Tue, Sep 12, 2006 at 1:33:36 PM
Members: | 2042257 | Objects: | 23026 | Forum Posts: | 152217 | Job Listings: | 3 |
