37 Users Online (35 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Community >> Newbies >> Newbie here...
Wed, Aug 10, 2011 at 10:26:45 AM | Newbie here...
flabs
...and glad to be part of the community.  I actually came with a question too!
when drawing a parking garage in REVIT, does it make more sense to draw the floor and warp it (similar to the youtube tutorial that is out there) or model the precast t's similar to how it would actually be built?  has anyone done a parking garage before?  any advice before i get started?
thanks in advance for your assistance and support.
Wed, Aug 10, 2011 at 11:05:20 AM | Newbie here...
My first Revit project was a pre-cast parking garage.  I modeled it as it would be built.  The floors were all sloped as they would be built and the precast spandrel panels all sloped accordingly as well.  If you look under my profile, you will see an image of that garage done in 2006.
Wed, Aug 10, 2011 at 11:30:58 AM | Newbie here...
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
I'm with WW, on this one, I assume you are using RST, I would absolutely model as it is to be built, else what is the point.
Wed, Aug 10, 2011 at 12:50:35 PM | Newbie here...
flabs
thanks for the replies all.  much appreciated!
just to clarify, when you say the floors were all sloped as they would be built, i am mostly curious at this time excactly how the floor was constructed.  Meaning, did you create 12'-0" x 60'-0" (+/-) precast t's (with 30" deep integrated beams) and use that as the basis of the floor structure OR did you use the floor command to create the floor like this:
http://www.youtube.com/watch?v=0mHjQE4vYEk
maybe i am too new to this program to properly verbalize my question.  i hope this makes sense, and i appreciate your assistance in advance.
also, i don't know what RST is, sorry...can you clarify please?
Wed, Aug 10, 2011 at 1:47:09 PM | Newbie here...
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
RST = Revit Structural
Wed, Aug 10, 2011 at 1:59:16 PM | Newbie here...
vector25
vector25 Avatar
2.5 Stars: 7 Votes
RST is one of the three versions of revit called "revit structure".. it is basically the same as revit architecture except that it works with structural analysis programs.. revit structure is able to differentiate between load-bearing and non load-bearing elements.. revit structure is for structural engineers..
Wed, Aug 10, 2011 at 2:10:25 PM | Newbie here...
flabs
thanks again.  i am not using RST, but there is a structural consultant as part of the team obviously.
i was planning on modeling the structural ts myself to form the basis of the deck...in your opinions, is that a mistake?
thanks again, this is really helpful.
Thu, Aug 11, 2011 at 3:32:40 PM | Newbie here...
vector25
vector25 Avatar
2.5 Stars: 7 Votes
if you get the load calcs close then that's all the less modification you will have to make when it's engineered..
Thu, Aug 11, 2011 at 4:09:57 PM | Newbie here...
We did not have RST so it was modeled in architecture.  The floor slab topping was a floor and was warped by using slope lines.  They sloped from corner to corner so the slope line was used in that direction.  There was no floor modification tools then like cadclips showed.    The beams and double tees were seperate families.
Thu, Aug 11, 2011 at 5:07:23 PM | Newbie here...
flabs
thanks all.  i have started by building the simple precast shear walls and modeling the floors using the floor modification tools like in the cadclips video.  it was really easy and looks great.  of course, i am still trying to figure out the best way to coordinate with structural, and determine who will be responsible for modeling the precast t's and whether or not they will be attached to the floor i have already created or modeled as a parametric family...we are just starting DD's, so i think there is some time for those decisions.  i dont want to go too far down one road and have to circle back.
thanks again for all the support...this is a great place.  happy to have finally entered the 21st century and become acclimated with this software...i have had so many projects not go forward that were slated to be full REVIT projects...
Newbie
Thu, Apr 27, 2017 at 9:35:54 AM
Revit MEP 2008 Newbie!
Mon, Oct 1, 2007 at 10:00:10 AM
Newbie needs help
Mon, Dec 28, 2009 at 8:45:28 AM
newbie from ohio
Sat, Jan 2, 2010 at 8:16:08 AM
newbie..
Sun, Nov 28, 2010 at 2:33:03 AM
Page generation time: 0.2237
