59 Users Online (58 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Systems >> Technical Support >> Revit Architecture 2012 - Section shows view from behind cut line
Wed, Aug 10, 2011 at 9:09:06 AM | Revit Architecture 2012 - Section shows view from behind cut line
Narcosis
Hi
I have encountered an unsual problem in one of my projects. For some reason when I cut a new section, the view I get is a view from behond the cut line and much further back than the view range should be.  This is very strange and annoying. The section line is deffinately facing the correct way and even if I set the view range to only 1m it still shows the same view some 50metres behind me.
The same problem does not occur if I open the project on another machine so therefore I think I must have changed a setting somewhere on my computer.
Any suggestions would be greatfully recieved
Kind regards
Narcosis
Wed, Apr 18, 2012 at 12:57:35 PM | Revit Architecture 2012 - Section shows view from behind cut line
geethomps
Narcosis,
I am having the same issue and can not find a solution. It tends to go away on its own, but then re-occur randomly elsewhere.
Have you had any luck solving this problem outsite this Forum?
Thanks,
geethomps
Wed, Apr 18, 2012 at 3:03:39 PM | Revit Architecture 2012 - Section shows view from behind cut line
Narcosis
Hi Geetomps,
We were haveing this issue with a Buffer model.  A Revit file with only linked models in it for doing sections and creating the sheets. (this is a big project).  we decided that the file was corrupted somehow and recreated a new one.  The problem hasn'r come back since so I assume that the file was indeed corrupt in some way.  Depending on your project, this may not be such an easy solution for you.  You may want to try copying and pasting your entire site and model into a new project.
Hope this helps, good luck
Narcosis
Thu, Jan 10, 2013 at 12:10:19 PM | Revit Architecture 2012 - Section shows view from behind cut line
ianOK
Anyone have any more info on this type of problem? I have two floor slabs that I have used the modify sub elements command to create a sloped floor surface for the bottom of a pond. One floor is the concrete bottom of the pond. The other floor is the earth under the pond modified the same, so they fit together nicely since the topo will not let you do such things. In 2012 it showed up just fine. Now that we upgraded the project to 2013 these two floors will not show as cut in any sections.
Thu, Jan 10, 2013 at 12:38:20 PM | Revit Architecture 2012 - Section shows view from behind cut line
geethomps
Since I last posted on the issue I encountered, I discovered the culprit. The section appearing to be cut from behind the view (the topic of this post, but maybe not specifically your issue) was caused by a linked model not having the same N/S & E/W coordinates as the host model. It was an easy fix, but I'm not sure why your visibility glitch occurs in 2013. We haven't had any 2012-t0-2013 conversion problems. Yet.
RAC 2012 - Structural Section View shows as Wireframe vs. Hidden Line
Wed, Mar 7, 2012 at 1:50:31 PM
Section line disappears from plan when section view is placed on same sheet
Thu, Sep 4, 2014 at 7:46:20 AM
Cut Geometry shows in 3D and Plan but not in Section?
Fri, Nov 30, 2012 at 1:44:30 PM
Walls not showing up on section cuts
Tue, Feb 7, 2012 at 2:52:55 PM
How to cut a section in an angle, other than 90 deg (revit 2012)
Wed, Jul 13, 2011 at 6:56:04 AM
Page generation time: 2.2858
