121 Users Online (120 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> General Discussion >> Revit Project Management >> Genereic annotations and shared parameters.
Wed, Aug 10, 2011 at 8:37:06 AM | Genereic annotations and shared parameters.
BizkiD
Hello i've been busting my head into the wall with revit all day and i hope you can end my misrey. When i want to create new generic annotion family and put shred parameters in a label so that i can the schedule it's parameters in the project, Shared parameter option ir greyed out and not avalble for selcting. Am i doing smth wrong here or what?
i need to make a symbol(number) that would be in site plan with numbers over the buildings and other objects/places and those number would comtain info about the object so that i could make schedule where there would be Obj Nr. Name etc.
I hope i  explaned myself enougth for you to understand what i want Smile
Wed, Aug 10, 2011 at 9:19:03 AM | Genereic annotations and shared parameters.
TKennedy
4 Stars: 7 Votes
You will need a tag, not a symbol. A symbol is just 'dumb' annotation, it can't read any information. A tag is hosted on an element and can display information about the element.
Thu, Aug 11, 2011 at 3:18:30 AM | Genereic annotations and shared parameters.
BizkiD
I need it to be dumb anotation that contains the info that i put in it and i need  that info that i typed in to be able to put in schedule.
how can  you make a tag for the shole building and the same tad that would mark parking lot and some other objects that are not buildings......Tags have to have objects to be hosted to and those tags read only one type of objects.... that's not what i need.
Thu, Aug 11, 2011 at 3:23:59 AM | Genereic annotations and shared parameters.
BizkiD
and i don't think that you can tag Objects on the site.....like is there a tag for the whole building?
Thu, Aug 11, 2011 at 7:12:06 AM | Genereic annotations and shared parameters.
3.5 Stars: 395 Votes
You can make a tag for any revit family category, including site items.  Just look in your annotations library and under site, you will find planting tags.  So create a family (could be an invisible family) that is placed with your buildings and contains the needed data.... and create a tag to tag it.
Fri, Aug 12, 2011 at 1:14:42 AM | Genereic annotations and shared parameters.
BizkiD
hmmm.....invisibile family eh? that's one way to do it. And probobly that will be the path that i will take IF i won't be able to do what i want to do cause that makes more sence to me cause it should be a lot faster and easyer, BUT i cannot get it to wokr. SO again i am askin is it possible to make a dumb anotation (witch is basicaly a text, a number) that has info nested inside that could be read of ir in schedules? when i make anotation family i can pu only family parameters and i don't think u can schedule them, as far as i can see you can schedule only shared parameters. but u cannot place shared parameters inside annotation label. is it impossible or am i missing smth here ?
Fri, Aug 12, 2011 at 6:43:43 AM | Genereic annotations and shared parameters.
I use IDF's all the time to carry tage information so I know they work.  You have to use shared parameters in the IDF in order to tag them - and you must assign the family to a category.
Fri, Aug 19, 2011 at 2:42:45 AM | Genereic annotations and shared parameters.
BizkiD
Don't want to sound like an idiot but here goes nothing... Smile what is IDF? lol
Fri, Aug 19, 2011 at 6:54:22 AM | Genereic annotations and shared parameters.
Invisible detail family...
Shared Parameters
Thu, Feb 9, 2006 at 1:41:58 PM
Shared or Project Parameters?
Tue, Jan 19, 2010 at 7:01:11 PM
Project Shared Parameters or Shared Parameters in Families
Fri, Feb 21, 2014 at 10:22:42 AM
Creating Shared Parameters
Tue, Nov 25, 2008 at 4:45:08 AM
Shared Parameters File is not a valid...
Wed, Feb 12, 2014 at 9:31:26 AM
Page generation time: 2.4217
