Forums >> Revit Building >> Tips & Tricks >> Section Plane
6 Posts No Rating |
Can i select any object to be not cutted by the section plane?
i'm rendering a first floor plan of a house and i want my tree outside to appear.
Can i do it someway?
thanks!
If it is a plan, look into using a plan region. Search PLAN REGION in your HELP.
6 Posts No Rating |
well, it's not a plan, it's an humanized plan but in 3d, rendered.
can i do it or the section plane will always cut it out?
I'm afraid the section box will almost always cut an object. The effect you're looking for could be done with two renders and photoshop, with ease.
6 Posts No Rating |
greeeeat idea, my friend. thank you!
do you people know if there's a plug in for doing the roof structure in wood?
in brazil they're called 'Scissors', i don't know how to say it in english, haha.
since it is a view from the top. for rendering purposes only you could could lower the elevation of the tree so that is not cut and drop the view range so that the tree is displayed.
Edited on: Tue, Aug 9, 2011 at 7:40:42 AM
Reference plane visibility in section |
Mon, Aug 27, 2018 at 7:11:50 AM
Section callout missing |
Mon, Dec 16, 2013 at 4:00:09 PM
Reference Plane Issues |
Tue, Mar 10, 2015 at 9:19:15 AM
Curved Celing |
Thu, Oct 25, 2007 at 6:05:37 PM
curtain wall mullion tapering with mass - Revit 2013 |
Tue, Nov 13, 2012 at 9:19:54 AM
Members: | 2119134 | Objects: | 23205 | Forum Posts: | 152300 | Job Listings: | 3 |
