81 Users Online (80 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Sheet/Template
Mon, Nov 28, 2005 at 10:58:18 PM | Sheet/Template
Richard45
Does anyone know if you can copy an electrical sheet/plan view from a residential project into a commercial? I have used a commercial template to start a project and now need an electrical sheet and the commercial template does not have one. Thanks Richard
Tue, Nov 29, 2005 at 2:21:15 AM | RE: Sheet/Template
eldados
eldados Avatar
4.5 Stars: 8 Votes
a little confused here Smile do you want to bring a sheet into your template or drawings? why can't you just "load family" (LF for short) and load your title block? title block have nothing to do with your template. or am I missing the whole point?? Smile
Integrator
KarelCAD
Sat, Dec 3, 2005 at 8:09:48 PM | RE: Sheet/Template
Richard45
I have started a project using a standard Revit commercial template which does not have the electrical sheet in it with all the proper display settings, however Revit's standard residential template has an electrical sheet set up an Iwould like to import that into my project, so that I don't need to figure out all the display settings. I may not be using all the correct terms, I have just started using Revit and know very little tricks yet. Thanks for your input. Richard
Correct family template for a sheet "stamp"?
Mon, Jun 27, 2011 at 5:10:23 PM
Sheet Template - editable text
Thu, Mar 5, 2009 at 3:40:42 AM
sheets pre set in template
Tue, Apr 10, 2007 at 11:36:32 AM
reloading updated template....?
Tue, Dec 16, 2008 at 12:07:45 PM
A4 sheet
Mon, Jun 21, 2010 at 11:06:02 AM
Page generation time: 1.2041
