74 Users Online (73 Members):
Forums >> Revit Building >> Technical Support >> revit structure 2012 add-in "integration with civil 3d": routing error?
![WinstonStoskopf Avatar](user_avatar/246297.jpg)
2 Posts No Rating |
I am trying to use the extension "Bridge: integration with AutoCAD Civil 3D" and am receiving the following error message when I try to use the tool:
"The required AutoCAD Civil or AutoCad Civil 3D version is not installed, detected or set as default. AutoCAD process not found."
How do I go about fixing this connection?
My info:
Windows 7 home premium, service pack 1
i7-2630 cpu, 2.0-2.8GHz
8GB DDR3 Ram 1333GHz
nvidia gtx m460 1.5gb
Revit Structure 2012 (student)
AutoCAD Civil 3D 2012 (student)
2 Posts No Rating |
ok... finally figured out how to get this to work... was simple as needing to have both revit and c3d running at the same time
Is this add-in works also with Revit Architecture?
and where to download it?
Error message when importing Robot Millennium buildingmodel |
Mon, Mar 5, 2007 at 5:13:15 AM
"auto" open in Revit 2012, when you have both 2012 and 2013 |
Sun, Jul 12, 2015 at 4:52:17 PM
Opening 2008 file in 2009 causes "Unrecoverable error" crash |
Tue, Jul 28, 2009 at 1:36:33 AM
"Constraints are not satisfied" |
Wed, Jun 7, 2006 at 8:17:24 AM
Print Error "Display Error" |
Tue, Dec 20, 2005 at 5:04:34 PM
Members: | 2016919 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
