70 Users Online (67 Members):
Forums >> Revit Building >> Technical Support >> Roof Slope Representation
97 Posts No Rating |
R2011:
When putting on a roof slope representation (marker) my default is always an arrow.... the style of it I can change. But I prefer to use a triangle.... Every view that I put a slope marker on, I have to go & change the arrow to a triangle.
I've been looking, but cannot find a way to change the default to triangle from arrow. Has anyone else seen this?
I usually use the 'Create Similar' to set my defaults. You can select the object you want to default to, right click, and select create similar. This will now be your default option for placement. Sometimes this turns into a global setting, sometimes it lasts for only a session.
Thank you for the tip....
I think if you select what you want in the options toolbar before you place it, Revit remembers your preferred setting. This works for other elements as well.
OH! For Pete's sake! I just realized that the selection option was there all the time! Thanks for making me look harder!
Roof slope not showing up correct |
Thu, Jul 11, 2013 at 10:37:30 AM
Roof's wont slope :( |
Mon, Apr 2, 2007 at 5:34:05 PM
Help slope tag showing wrong slope |
Thu, Feb 27, 2014 at 8:21:23 PM
Roof slope line incorrect |
Wed, Sep 30, 2009 at 6:28:37 AM
Roof Join with Joining roof slope cutback |
Tue, Jun 26, 2012 at 6:29:25 PM
Members: | 2030502 | Objects: | 23003 | Forum Posts: | 152205 | Job Listings: | 3 |
