Forums >> Revit Building >> Technical Support >> window families
Hi
i create a new window family (triangular on this occasion,) when importing to a wall, the opening holding the window is not cut out, the window seems to be embedded in the project, can anyone explain where i am going wrong please,
Thanks
Will
Ok panic over everybody,
i simply used the opening tool, (why didnt i think of that earlier????)
you can use the opening tool, but something is wrong in your family, make sure the reference lines are locked to the wall and in the right place...
Could you explain the steps you followed to create your windlw, that way I could think of what are you doing wrong. Can you send the family to check and what variations do you want ot obtain out of this family?
WINDOW FAMILIES |
Thu, May 24, 2007 at 5:46:10 PM
Better Window Families |
Tue, Aug 30, 2005 at 4:25:34 PM
Curtain Walls vs Window Families |
Tue, Sep 13, 2016 at 7:14:42 AM
Fleetwood window families unable to offset form exterior |
Tue, Oct 18, 2016 at 10:24:43 AM
Nested window mullions (Generic Models) don't appear in Window Schedule |
Wed, Apr 30, 2008 at 11:33:21 AM
Members: | 2114525 | Objects: | 23192 | Forum Posts: | 152319 | Job Listings: | 3 |
