Forums >> Revit Building >> Technical Support >> Deleted objects still visible on other levels
4 Posts No Rating |
When I delete a colomn in Revit Structure on level 00 and I go to level +1 it is still visible there.I design with Revit Architecture and Structure and had never before this problem.
Rudy
If you still see it, then it is still there. You had to have multiple columns in the same place.
(This is not a copy monitored column in the architectural file is it?)
4 Posts No Rating |
Thanks for the reply, no it are not columns I've copied with the copy monitor. When I look In 3D they are gone.. It's verry bizar. It's like the database can't follow the design...
OK... Now it sounds like you have a detail element in this plan. Did you look at its properties or just assume it was a model column?
4 Posts No Rating |
Yes, and when I look at the ID nr of the colomn it's the same nr of the one I deleted so it's the same column who's still visible
Please post an image of this column's properties. Also look at your 3D view and make sure its VG settings include the column category. Make sure the plan and this 3D view have the same phase settings.
4 Posts No Rating |
Thanks for the help but I found the solution for my problem: I created a shortcut for the delete command and sometimes it did'nt work properly. when I now delete an element it is gone. Thanks anyway for your help.
