67 Users Online (65 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Problems with linked files and interior elevations
Mon, Aug 1, 2011 at 6:01:13 PM | Problems with linked files and interior elevations
golear
I have linked a file into an existing file to layout millwork. I am able to create interior elevations on the first floor of the model, but when I try to create elevations of the millwork on the second level, nothing shows up. Also, when I go to place the elevation tags on the second level, they show up on the first level, and I can see the elevation tags that were placed on the first level on the second level. I have been trying diffrent thigns with regard to view range, but it doesn't seem to work. Any suggestions?
Tue, Aug 2, 2011 at 7:48:34 AM | Problems with linked files and interior elevations
I hav e feeling this is a work plane issue.  Are your plan views true views for the level or are they duplicated views with a change in view properties?  You should be creating your plan views from the ribbon - view / plan views tab and selecting your level.
Wed, Aug 3, 2011 at 7:59:53 AM | Problems with linked files and interior elevations
golear
Thanks! I tried some diffrent work plane settings in addtion to your suggestion and I got the results that I was hoping for.
autocad linked files and refresh
Tue, Apr 7, 2009 at 2:12:37 PM
View Properties of Linked Revit Files
Mon, Feb 15, 2010 at 9:56:23 PM
Dimensioning across multible linked files
Fri, Jan 15, 2010 at 10:33:17 AM
Problem with Interior elevations
Fri, Feb 13, 2015 at 1:51:30 PM
Revit Export to AutoCAD DXF/DWG problems with linked files
Wed, Aug 27, 2008 at 9:42:44 AM
Page generation time: 0.6864
