72 Users Online (71 Members):
Forums >> Revit Systems >> Technical Support >> Pendant sprinkler head not hosted
![3 Stars: 1 Votes](/images/stars_3.gif) |
Is there a pendent sprinkler head that anyone has that is not hosted? I am showing existing heads in a warehouse and there is no ceiling. The ones that come with MEP2012 really are genric. LOL Seems all families on download are hosted.
There are unhosted ones on the AutoDESK SEEK site.
I looked there, and I searched under Revit and Sprinkler head and only found 13 items, none of which were a sprinkler head, they were detail or flexheads. If you know of one could you provide a link? needs to be for MEP, or maybe I can take an architectural one and modify it by adding a connector if thats would work.
Your right - sorry.
Why can't you use the sorry for the text size - cut and paste from site
Dry System Upright Sprinkler, 5.6 K Factor, 30 GPM Flow Rate, 2" Overall Length, 1" Nominal Diameter, 7.0 psi Pressure Drop ... and modify its parameters.
Edited on: Thu, Jul 28, 2011 at 3:04:01 PM
Well, it needs to be a pendent. Can an upright be used for a pendent, meaning can it be rotated? It also has to not be hosted.
Edit the family and turn it around.....
I didnt know it could be rotated, but more importantly I didnt know you can take a familty that is hosted and make it non hosted.
Difference between selecting object in 3D view and ceiling plan view? |
Sat, Jul 30, 2011 at 11:30:06 AM
Creating a Sprinkler Tag and Schedule |
Mon, May 24, 2010 at 12:08:43 PM
MEP QUERY - Sprinkler system showing route in angle |
Tue, Mar 3, 2009 at 10:02:18 PM
Pendant light placement |
Wed, Sep 19, 2007 at 4:03:08 PM
sprinkler heads |
Tue, May 5, 2009 at 8:32:09 AM
Members: | 2017209 | Objects: | 22947 | Forum Posts: | 152212 | Job Listings: | 3 |
