106 Users Online (104 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Need to get ceiling based mechanical hood to show up in floor plan
Wed, Jul 27, 2011 at 5:14:28 PM | Need to get ceiling based mechanical hood to show up in floor plan
citroen
How can I get the mechanical hood to show in my floor plan as a dashed line?  I need to do this so I can get the special equipment tag to show up on plan.  I created this hood as a ceiling based component and used symbolic lines at the ceiling reference plane.  I originally created this in plan view but it would not show up in my ceiling plan so I had to recreate it as a ceiling based component.  I also adjusted the viewplane on my model where I imported this family component but doesn't work.
any ideas?  I am using Revit 2008.  I attached the family component for your reference.
Wed, Jul 27, 2011 at 8:43:31 PM | Need to get ceiling based mechanical hood to show up in floor plan
lab21
You need to add an element within you component that will be seen below the cut plane in the project. Confused?
Try this. Add an ‘Invisible model line’ at floor level in your family. Change your cut plane in the plan view so you're not cutting through you range hood and load into project. Now in your project you will see the ‘Invisible line’ in plan so Revit will therefore show the symbolic line from that view (dashed lines). Your Reflected ceiling plan will show as normal.
I would have amended the family and reloaded it but I’ve only got 2011/2012.
Luke
To use or not to use . . Floor plan or Ceiling plan . . . for Mech and Lighting
Tue, Sep 13, 2011 at 11:12:10 AM
Revit 2011 - show ceiling-hosted objects on floor plan?
Tue, May 3, 2011 at 5:47:49 PM
Show ceiling/roof lines as hidden lines on floor plan
Mon, Aug 17, 2009 at 12:24:45 PM
Lines in Ceiling Plans
Wed, Oct 24, 2007 at 4:44:58 PM
Copy Plans
Mon, May 11, 2015 at 10:30:59 AM
Page generation time: 2.5201
