46 Users Online (45 Members):
Forums >> Revit Building >> Technical Support >> How to assign a standard family type to an In-Place object?
13 Posts No Rating |
Hi All,
I am fairly new in Revit and am trying to self learn in from scratch so please forgive me if that may sound obvious.
I make an object using in-place family (let say a floor for example) but I am wondering how can assign a standard floor type to it? Or if it isn’t possible then how should I define a structure for it in way that I’ll be able to edit its family type later on?
Many thanks
Kayvan
![3.5 Stars: 7 Votes](/images/stars_3.5.gif) |
You cannot change and in-place family to another family. In-place families should be used (in general) for only single-instances of unique geometry.
Check this out and see if it helps. I have not yet looked at it.
http://whatrevitwants.blogspot.com/2011/07/save-in-place-family-as-rfa-for-use-in.html
i stand corrected...
Thanks for replies, therefore emgeeo please correct me if I am wrong: for example if I make a floor by in-place then when I make section through it I will see its construction just as unify single object.
Any way of assigning Family and type to model in place ? |
Fri, Sep 14, 2012 at 8:01:09 AM
Create Roof Family Object |
Mon, Nov 21, 2005 at 7:10:42 PM
is there any way to transfer family object to instance object or something like |
Wed, Jun 1, 2011 at 7:10:55 AM
line style in plan view |
Thu, Mar 4, 2004 at 12:47:43 PM
assign different subcategory to labels? |
Wed, Feb 16, 2011 at 3:11:06 AM
Members: | 2022374 | Objects: | 22974 | Forum Posts: | 152201 | Job Listings: | 3 |
