36 Users Online (34 Members):
Forums >> Revit Building >> Technical Support >> How to sweep a window frame?
10 Posts No Rating |
I am creating a detailed window frame as shown in the attached picture. However, I am having trouble making it sweep. Is there an easy way to do this?
I am using Revit Architecture 2011.
![itsmyalterego Avatar](user_avatar/109615.jpg)
it should work fine as a sweep, you just need the profile, and a path. What seems to be the problem? The only problem I can imagine is if you're trying to make it wrap 360 degrees around the cut in the wall, and it's handling the 90-degree angles poorly...?
Sometimes really complex little angles and curves in your profile can have trouble navigating bends in a sweep's path.
Pic attached. For a sweep like this, use "pick 3D edge" for your path.
Edited on: Wed, Jul 27, 2011 at 4:00:55 PM
Thank you that worked perfect!
25 Posts No Rating |
What's the advantage of using such a detailed window frame?
Palm Springs Architect using Revit LT! |
It would be a drag on your project if it's larger than a small home, if you get involved with that level of detail.
However, you could make some awesome 3D details like this.
We are required to make every model, etc. as realistic as possible so that we do not have confusion in the field. I think if anything it is more of a liability issue.
Revit 2013 - Window frame sweep with wall thickness |
Wed, Nov 28, 2012 at 4:03:26 AM
window frame family + nested window frame fill |
Wed, Apr 12, 2006 at 7:31:30 AM
making a profile a parameter |
Fri, Apr 15, 2011 at 10:18:14 AM
Custom Window Frame |
Tue, Aug 2, 2011 at 12:31:51 PM
Need a little help with understanding families |
Mon, Jun 23, 2008 at 5:05:35 PM
Members: | 2022349 | Objects: | 22974 | Forum Posts: | 152200 | Job Listings: | 3 |
