68 Users Online (67 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Projection Lines
Fri, Nov 25, 2005 at 5:39:52 PM | Projection Lines
Kassner
Hi.... Could anyone tell me why elements like walls and windows that belong to first floor, does not show in ground plan with hidden line style? I check cut plane, top and bottom planes... Everything is ok. My solution to this problem is put level above in underlay and sketch lines over some elements that i want to project in floor plan. I hope can anyone understand me because my english is not so good... Thanks anyway.
Sun, Nov 27, 2005 at 5:47:35 PM | RE: Projection Lines
eldados
eldados Avatar
4.5 Stars: 8 Votes
if you are saying that you check the cut line and it's good (it is cutting through the window?) check your display settings and set to medium or fine, as well, check your window family and make sure visibility is turned on for all of it... HTH
Integrator
KarelCAD
why my projection lines overlap cut lines.
Tue, Apr 10, 2018 at 7:41:07 PM
projection vs. cut lines
Mon, Oct 31, 2005 at 2:29:38 PM
Toggle cut and projection lines
Tue, Mar 6, 2012 at 6:57:56 AM
Projection Lines - Too Many Lines With Curves
Tue, Jun 3, 2008 at 7:32:05 AM
Walls' projection lines - how to turn them off?
Wed, Jun 26, 2013 at 4:00:09 PM
Page generation time: 0.5395
