75 Users Online (74 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> General Discussion >> Revit Project Management >> Adding options in the properties for doors
Mon, Jul 25, 2011 at 11:08:36 AM | Adding options in the properties for doors
Natasha00123
I have a door in my curtain wall. I want to change some of it's informations in the schedule but to do so, I have to click on the door and edit it's properties. Well, the option I need to have filled in is not in it's properties, nor when I click to edit type. How do add to the options that I see when I lookin in a doors properties?
...another instance, it I have a glass slider door I'd like to also add more options to it's properties.
Thanks,
Natasha
Tue, Sep 6, 2011 at 1:39:31 AM | Adding options in the properties for doors
mikeinsverige
In the project browser, in the families section, find the curtain wall doors (panels) you want to modiyf. Right click and say edit family.Then in the family properties you can add new parameters, then reload it to your project.
Tue, Sep 6, 2011 at 7:46:17 AM | Adding options in the properties for doors
3.5 Stars: 395 Votes
It is not as simple as just adding a parameter to the family.  If it is a family parameter, it has to be the same parameter - not just named the same.  And schedule only parameters are not in the family at all.
I suggest you first look at your schedule and the parameters you need.  Make sure they are not just added in the project.  If they are, you should be able to change them in the schedule.
If you would post what information you need in the family, we could help more.
adding more appearance properties options?
Wed, Apr 17, 2013 at 1:20:21 PM
Adding Doors
Wed, Oct 17, 2012 at 1:01:15 PM
Wish Match Properties tool worked while adding new walls or components.
Tue, Apr 22, 2008 at 9:48:50 AM
Adding New Mullions to your Mullion Tab Options
Wed, May 11, 2011 at 5:51:35 PM
dOORS AND DOOR SCHEDULES
Mon, Aug 6, 2007 at 11:28:15 AM
Page generation time: 0.6671
