71 Users Online (69 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Structure >> Technical Support >> Beam Splice Recommendations
Fri, Jul 22, 2011 at 2:33:37 PM | Beam Splice Recommendations
gregroberson
gregroberson Avatar
What is everyone doing for dimensioning beam splices in plan view? . . If I try to edit one the whole beam moves!  I have tried dimensioning to every part (shape handle etc . . ).  I would like to have a splice in where i could click the beam, edit the dimension and have the beam and the one it is spliced to move to the appropriate dimension.
Any Ideas, Greg
Mon, Aug 1, 2011 at 10:06:17 AM | Beam Splice Recommendations
emgeeo
3.5 Stars: 7 Votes
I was able to get this to work with a reference plane, and deleting constrained dimensions.
Mon, Aug 1, 2011 at 10:12:39 AM | Beam Splice Recommendations
emgeeo
3.5 Stars: 7 Votes
You could probably get this to work with a detail component acting as the reference plane, since you probably are using a detail component/graphic for the beam slice anyways.
laptop spec recommendations
Sun, Aug 6, 2006 at 12:19:13 AM
Meeting Beam Systems to Glulam Beam
Wed, Jun 20, 2012 at 10:34:17 AM
Precast Beam System not sitting on beam
Thu, Jan 10, 2013 at 11:45:49 AM
Steel Beam to Beam Connection
Fri, Jun 18, 2010 at 1:54:37 PM
Beam & Beam systems
Tue, Oct 21, 2008 at 4:36:55 PM
Page generation time: 1.3335
