86 Users Online (85 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Array Formula Problems
Fri, Jul 22, 2011 at 7:37:15 AM | Array Formula Problems
cundall
Can anybody tell me where i am going wrong with this generic line array family within the attachment ?
I want to be able to add a new Void every 225mm when i extend the line. the first time i tried to do it i got a error message saying ''THERE IS A CIRCULAR CHAIN OF REFERANCES AMONG THE FORMULAS''  so i decided to start again from fresh but i am getting nowhere with it.
Thanks
Fri, Jul 22, 2011 at 8:40:19 AM | Array Formula Problems
emgeeo
3.5 Stars: 7 Votes
i don't understand the logic of your family...
it is a structural framing member nested into a line-base generic model family.  Since the beam family is line-based anyways, why load it into another line-based family?  You should be able to accomplish everything you need in the beam family.
If I understood the context in which you are using this family, I might be able to help you more.
I say this because you speak of voids, but I think you really mean clear spacing between elements.  Please clarify what you intend to use the family for.
Fri, Jul 22, 2011 at 9:52:10 AM | Array Formula Problems
cundall
Sorry i didnt really explain what i wanted to achieve, im trying to make a windpost column with voids as the hole fixings. the hole fixings (voids) are @ 225c/c, so i wanted to make the windpost to add a new void when it is extended over 225mm.
Im new to families so i thought that you could only do this by using a generic line based family. i want to get used to working with formulas because i dont no very much about the rules and the way you have to type them.
please see the attachment below to have an idea what i mean. i just want the voids to automatically add itself when i increase its height.
thanks for your time
Sun, Jul 24, 2011 at 11:47:46 PM | Array Formula Problems
lab21
Try this.
Arrayed parameters can be tricky things. To add a parameter to an array, right click on the array line (just under the number) and select 'edit label'
I swapped out the void extrusion for a nested void component (more efficient) and added a parameter for your centres.
open up the file and have a look around.
Luke
Mon, Jul 25, 2011 at 3:41:25 AM | Array Formula Problems
cundall
lab21 any chance you could make it in 2011 please i only have that version ?
is there any good tutorials out there aswell on array formulas ?
thanks for your time, much appreciated.
regards
Edited on: Mon, Jul 25, 2011 at 3:45:21 AM
Edited on: Mon, Jul 25, 2011 at 3:45:41 AM
Mon, Jul 25, 2011 at 6:18:42 PM | Array Formula Problems
lab21
This time!
There's a  good tutorial here on RevitCity http://www.revitcity.com/tutorials/arrays_and_nested/ by Mr Spot. it's from a while back, but still good.
Tue, Jul 26, 2011 at 2:30:55 AM | Array Formula Problems
cundall
cheers lab21 cant believe how easy youve made it look.
thanks alot
Family w/ Array Formula
Fri, Mar 23, 2007 at 9:29:38 AM
Array Formula
Tue, Dec 9, 2008 at 11:11:52 AM
Array formula (9.1)
Mon, Sep 24, 2007 at 7:12:48 PM
Beam Family Array Formula Help
Thu, Oct 23, 2014 at 9:40:35 AM
Variable Length Family with Array Formula
Wed, Aug 8, 2012 at 9:56:47 AM
Page generation time: 1.4069
