38 Users Online (37 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Rev 2009 Importing Structural Dwgs into Arch dwg
Thu, Jul 21, 2011 at 1:35:48 PM | Rev 2009 Importing Structural Dwgs into Arch dwg
tmassey
tmassey Avatar
Hello. Is there a way to turn off the annotation in our struc consultants rev dwg when we load them into our project. we only want the struc information...beams columns L angles etc..not there levels, grids etc.
Currently we are loading the struc then going into view graphics revit links custom and turning off the annotation categories for each section or call out view. with 140 callouts that is alot of tedium
cheers
Using Revit Architecture 2012
Thu, Jul 21, 2011 at 1:55:22 PM | Rev 2009 Importing Structural Dwgs into Arch dwg
View templates....
Thu, Jul 21, 2011 at 2:09:53 PM | Rev 2009 Importing Structural Dwgs into Arch dwg
tmassey
tmassey Avatar
 A little more clarification please. I import the structural into a view template and get rid of all annotation that we do not want?
Thu, Jul 21, 2011 at 2:34:36 PM | Rev 2009 Importing Structural Dwgs into Arch dwg
You don't import into a view template.  You assign a view template to your views.
Are you working in your view with linked model or linked views?  These are different.
For your model views, just set up a view template that manges the linked files ... yes - turns off all annotations, plus whatever elese you need.
Thu, Jul 21, 2011 at 2:58:46 PM | Rev 2009 Importing Structural Dwgs into Arch dwg
tmassey
tmassey Avatar
we created a view template for the structural/mech/elec engineers dwgs to be incoporated as a link in our arch. teh problem is that we ard crashing when we try this. we are working in a view with the linked dwgs from engineers
Thu, Jul 21, 2011 at 3:33:16 PM | Rev 2009 Importing Structural Dwgs into Arch dwg
You are confusing me because you are using the term dwg.  You said "rev dwg" initially so I assumed you really meant views from a linked Revit structural project.  Now you simply say "dwgs".  You don't say CAD imports but linked ... so are you talking about linked DWG's or linked REVIT?
View templates are just that.... a template that controls a view.  It can control linked items in that view but otherwise has nothing to do with linking CAD or Revit.  So this statement is also confusing.  Or did you mean you gave the engineers some sort of file to use for their DWG's and you are calling this a template?
Fri, Jul 22, 2011 at 8:04:17 AM | Rev 2009 Importing Structural Dwgs into Arch dwg
tmassey
tmassey Avatar
For randomly replying about the thread post, is there a free toaster the higher your rating is on this site?
If I started MY post with our struc consultants rev dwg why would you assume that 2 posts later on the same thread I was talking about autoCAD dwgs? This is a well intended forum but I find that most of your replies are pompous, arrogant and thin. I try to be as clear as I can with my posts. I don't need you to point out how confusing they are. If you don't understand where I am coming from stop replying.
Fri, Jul 22, 2011 at 11:25:30 AM | Rev 2009 Importing Structural Dwgs into Arch dwg
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
Because while dwg might be confused with the type of file as opposed to as you seem to use the term as a contraction for drawings. It is common on this forum to use dwg's meaning a file type which for Revit models not drawings would have a file type of .rvt. Where AutoCAD drawings would have a file type of .dwg.
Mon, Jul 25, 2011 at 7:39:15 AM | Rev 2009 Importing Structural Dwgs into Arch dwg
tmassey
tmassey Avatar
thank you...having a rough day on friday
Revit 2009 Importing Structural Dwg
Thu, Aug 25, 2011 at 2:31:17 PM
REV 2009 titleblock arch stamp
Thu, Jun 30, 2011 at 3:39:35 PM
Rev Arch 2009 conultants elelments in copy monitor
Wed, Aug 31, 2011 at 2:21:36 PM
When I import REV. ARCH Link, it lands way outside my work space
Fri, Oct 9, 2009 at 12:22:40 PM
OverHead Door creation Rev 2009
Mon, Jun 27, 2011 at 9:34:37 AM
Page generation time: 0.6010
