106 Users Online (105 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Doors are missing in plan
Thu, Jul 21, 2011 at 10:50:45 AM | Doors are missing in plan
CEJOHNSON713
We downloaded an adustable door from RevitCity to have the capability to adjust the door swing and we are having issues displaying it in plan view.  We have a multi-level building that varies 6 ft over the entire project.  The doors were all added in on the 0'-0" layer.  We have created views for each of the different levels so that we can drop in model compenents to display properly in Interior Sections and Elevations.  The problem is now that I am moving the doors to be located on their correct level, The frame shows up, but the doors disappear in plan.  I have seen that the cut plane in a family can be different than the cut plane in a plan view, but I do not see anyplace where I can change this.  Is this the problem, and if so, how do I fix it?  Or is it something else entirely?
Fri, Jul 22, 2011 at 8:42:47 AM | Doors are missing in plan
emgeeo
3.5 Stars: 7 Votes
post a screen-shot with a door in plan, and both the type and instance properties clearly visible.  What you are describing is a bit difficult to understand.
Walls, Windows Furniture ect missing on level2 plan
Sun, Aug 16, 2009 at 5:42:55 AM
Doors on plan vs elevation
Thu, Jan 14, 2016 at 7:48:16 AM
Structural plan is missing from View tab> plan views
Mon, Apr 29, 2013 at 8:04:26 AM
Importing IFC into Revit 2020. Windows/Doors not showing in plan/elevations/sect
Tue, Feb 4, 2020 at 6:15:58 PM
Doors in plan
Tue, May 13, 2014 at 1:44:50 PM
Page generation time: 1.4652
