87 Users Online (86 Members):
Forums >> Revit Building >> Technical Support >> Project Neon
3 Posts No Rating |
hello ...I'm revit user , I want to use the project neon for revit 2012, but when i want to do the render online, appears to me the message: a problem occurred. The file could not be translated. I turn off the firewall, but the problems is the same. can someone give me a hint?
![coreed Avatar](user_avatar/14568.jpg)
see if this link helps:
http://revitclinic.typepad.com/my_weblog/2011/06/revit-2012-project-neon-rendering-service-error-message.html
3 Posts No Rating |
Thank's coreed but the problem is not that.
![ArchiN00B Avatar](user_avatar/160085.jpg)
![4.5 Stars: 4 Votes](/images/stars_4.5.gif) |
Hi all
I have a similiar problem. I have a file that is 96mb and I'm trying to render an exterior rendering through Project Neon. I have tried an exterior and an interior rendering at high quality, png, screen size. Both times, Revit has crashed, giving me the following message:
"A fatal error occurred. The application will be terminated. You have the opportunity to save recovery files for all of your changed projects. Would you like to save a recovery file?"
Important to note: The file was created entirely in Revit 2011 and now I'm trying to Render it with Project Neon through 2012, after it has been updated and opened in 2012. Could this be causing the problem?
Many thanks if you can help!
3 Posts No Rating |
I THINK THE PROBLEM IS THE OPERATIN SYSTEM. IN MY CASE MY COMPUTER IS WINDOWS XP, I TRIED IN OTHER COMPUTER WITH THE O.S. VISTA AND THE PROJECT NEON WORKS GOOD.
Neon signs |
Mon, Dec 17, 2012 at 8:01:37 AM
NEON LIGHTING |
Fri, Jun 29, 2007 at 1:43:42 AM
Neon/ Glow in the Dark Signs/Lettering Anyone |
Tue, Oct 28, 2008 at 8:16:26 AM
how to put neon light on facade ? |
Fri, Apr 8, 2016 at 9:25:00 AM
quick 2012 question |
Sat, Jun 18, 2011 at 10:31:12 PM
Members: | 2017156 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
