Forums >> Revit Structure >> Technical Support >> Hidden Line . . .? not for me
140 Posts No Rating |
I am looking in an elevation view using RST 2011. I have the view's visual stlye set to hidden line. Shouldn't this dash the profiled behind my members with a "hidden-line"? In stead, I cannot see any elements behing my member. They are there, I can see them in wire-view. Any Ideas?
Greg
Hidden line hides lines that are hidden, it does not convert them to hidden line. To show hidden objects, read this topic in your HELP: Showing Hidden Element Lines
WWHub,
ALWAYS IMPRESSIVE. THANKS
Another thing to check is if the view discipline is set to Structural. IIRC, if it's a structural view Revit should automatically show hidden lines.
First of all, thanks for the link, I found my answer right away and am ashamed for not searching there first as is always stated on this site. . . "read you help file".
I figured out a bitr more though and thought I would share. If the discipline is set to "structural" in lieu of the coordination I was using to see walls and windows. . . all elements appear to automatically are seem as hidden lines when behind another object.
Greg
Exporting quality hidden line views |
Fri, Jul 8, 2005 at 4:02:24 AM
Line Styles Adjusting with Wall Hidden Lines? |
Mon, Mar 12, 2018 at 12:58:30 PM
Hidden line Help!!! Please! |
Thu, Sep 20, 2007 at 7:04:31 AM
Show Hidden Line - Not working the way I want it to |
Mon, Nov 19, 2012 at 10:52:44 PM
Revit MEP (Modify -> View -> Line work -Line Style) question |
Fri, Jan 14, 2011 at 9:50:56 AM
Members: | 2101011 | Objects: | 23173 | Forum Posts: | 152293 | Job Listings: | 3 |
