75 Users Online (72 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Walls set as existing not showing up in existing phase settings.
Tue, Jul 19, 2011 at 12:42:52 PM | Walls set as existing not showing up in existing phase settings.
keyaggie
I have modeled an existing house and set all the elements as created in the 'existing' phase.
I created a new phase filter to show existing & demo.  But when I assign the filter to the plan view, the existing walls and such do not show up, they only show up when the NEW phase is set to 'by category' in the phase filter.
I am not getting why existing is only visible when new is on, when all the elements are existing???
Tue, Jul 19, 2011 at 2:41:04 PM | Walls set as existing not showing up in existing phase settings.
keyaggie
I figured out I needed to set my phase for each view to 'new' in order for the filters to work properly.
Fri, Aug 3, 2012 at 3:58:40 PM | Walls set as existing not showing up in existing phase settings.
ylime824
I am having the exact same issue, but it doesn't make sense to have to switch the views to new, when they are not.  I hav't had to do this before in any project, so I am very confused.  Does anyone out there know???
THanks!
Sat, Aug 4, 2012 at 11:21:58 AM | Walls set as existing not showing up in existing phase settings.
You need to spend some time understanding the phase process and settings.  Your HELP is the best place to start.  Then if you have specific questions, we can help.
New Construction phase cuts Existing Phase
Tue, Aug 9, 2011 at 12:21:57 PM
Existing Walls with Coarse Fill Pattern Revit 2008
Wed, Aug 13, 2008 at 3:28:01 PM
Existing Walls Not Showing detail
Tue, Feb 6, 2018 at 2:53:46 PM
new doors in existing walls
Wed, Jun 30, 2004 at 3:13:03 PM
inserting objects into "Existing" phase
Fri, Jul 12, 2013 at 3:06:14 PM
Page generation time: 1.2018
