Forums >> Community >> The Studio >> Divide Parts question for Revit Certification
I'm taking the Revit certification test next week and to prepare I found an unofficial practice exam online from a 3rd party resource. I just want to confirm one question with the Revit community:
To divide a floor or wall into parts, you can use the following (select all that apply):
A. Lines
B. Levels
C. Grids
D. Circles
E. Arcs
The answer they are looking for is A,B,C & D. I disagree though, using arcs in sketching a division is no problem right? I would just select them all.
How would you divide a floor or wall in parts using Grids or Levels?
use Intersecting Reference command. Once you hit that, a list of all your grids and levels appears and anywhere they intersect with your component, a division cut will be made.
did you ever confirm this as being correct with them? Last thing i want is to take a test and the test itself is wrong...
also, care you share the source of the unofficial practice exam? thanks!
Edited on: Wed, Aug 3, 2011 at 11:50:24 AM
Here's is the link:
http://www.sdcpublications.com/pdfsample/978-1-58503-679-0-2.pdf
I wrote the exam last week and this didn't come up. It was fairly easy, anyone with significant experience shouldn't have a problem.
don't be suprised if the test itself is wrong, I did a cert at AU and one of the questions had a solution that did not match any of the answers. Not really a big deal though, the certification doesn't really mean much and is extremely easy.
SDC has a book for sale also on the CERT exam also.
Edited on: Wed, Aug 3, 2011 at 1:25:47 PM
67 Posts No Rating |
There's also a book to practice for the exam at www.revitexamtrainer.com. Has 450 questions, and has been very helpful.
how to divide a line or object in equal parts? |
Tue, May 14, 2019 at 5:50:59 AM
12
Revit 2012 - Parts won't divide |
Tue, Mar 18, 2014 at 3:37:44 PM
Dividing a 2d line |
Thu, May 26, 2005 at 11:00:53 AM
Divide comand |
Wed, Jan 3, 2007 at 4:19:23 PM
Dividing a section into equal parts |
Sat, Jul 22, 2006 at 9:45:11 AM
Members: | 2099093 | Objects: | 23170 | Forum Posts: | 152292 | Job Listings: | 3 |
