41 Users Online (40 Members):
Forums >> Revit Building >> Technical Support >> Wall section box controls
Hello,
I just cut a wall section and used the section box controls to break it down into 3 sections. I want to be able to adjust the vertical control of each box independently but when I move one of the bottom controls it moves them all. Can this be done?
Thanks
Also can I split scetion boxes in the horizontal direction?
Read this in your HELP:> Resizing Crop Regions Graphically
It is vertical or horizontal - not both.
I see, it seems like once you use the break lines vertically you can't use the horizontal ones too. This didn't say anything about resizing the split region independently.
Thanks
Yes it does tell you how to resize them.... Unless you mean the external crop region, that is one setting but the internal split lines are independent.
Section box in Section?? |
Sat, Dec 10, 2011 at 10:23:01 PM
13
Section Box through wall is solid color. |
Fri, Sep 11, 2009 at 3:56:15 PM
3D Section Box |
Thu, Nov 1, 2012 at 11:00:40 AM
"True" Shadows in Section Box (Section Perspective?) |
Tue, Nov 15, 2011 at 6:02:21 PM
Attach Building Section Heads to Section Box |
Mon, Sep 21, 2015 at 4:53:57 PM
Members: | 2056557 | Objects: | 23074 | Forum Posts: | 152325 | Job Listings: | 3 |
