64 Users Online (62 Members):
Forums >> Revit Building >> Technical Support >> Rotating View Name
Hi all,
I’m trying to rotate an elevation's view name while leaving the view tag in place. I’m working with 2010 and it seems there is no way to create a new elevation tag family . I also checked the setting for the view name in the setting dropdown menu but couldn’t find anything . suggestions, anyone?
You do know that you can rotate the view on a sheet and the tag rotates with it?
Of course - I'm trying to rotate only the elevation view name, not the view itself.
So your view text is normal with the sheet and the title is not? <<< That is strange.
If you are not concerned with the the above.... then you would have to create a different view title family type.
OTHERWISE - The answer was given in my initial response if you think about it.
Take a look at the attachement - I dont think we are on the same page.
We sure were not. I was talking about view title, not the view call-out.
Sorry, you would have to create a spectial view call-out tag to do this. We use numbers only and don't include the view name for this reason .... and others. Just no room in most cases.
Rotating Views On a Sheet [ 1 2 ] |
Tue, Jun 17, 2008 at 12:49:46 AM
18
Rotating View Titles |
Sun, Feb 8, 2015 at 2:10:09 PM
Rotating Symbol geometry without rotating leabel |
Wed, May 6, 2009 at 8:33:58 AM
Rotating Topo |
Wed, Feb 3, 2010 at 6:45:53 PM
Rotating the view |
Tue, Mar 18, 2008 at 8:14:46 AM
Members: | 2030502 | Objects: | 23003 | Forum Posts: | 152205 | Job Listings: | 3 |
