60 Users Online (59 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Decals not Rendering in 2010/12
Mon, Jul 18, 2011 at 11:34:52 AM | Decals not Rendering in 2010/12
ChChChChela
ChChChChela Avatar
Hello I'm working in Revit 2010 and I have a couple of decals on my walls.  When I tried rendering, none of them will show up.  So I tried exporting it in 2012 and I was able to get some of the decals to show up but some are still missing.
I've tried going to Options>Render and repathing.  I've also tried putting everything on my C drive.  It shows up when I go to properties.  I do not know what is going on.
-Chela
Edited on: Mon, Jul 18, 2011 at 11:46:01 AM
Mon, Jul 18, 2011 at 12:46:49 PM | Decals not Rendering in 2010/12
In most instances when a decal will not render, users do not place the decal on the correct face.
Mon, Jul 18, 2011 at 1:30:21 PM | Decals not Rendering in 2010/12
ChChChChela
ChChChChela Avatar
Thank you, it worked!  I tried placing it in 3d with Model Graphic style "Realistic with Edges" showing so I could see it working on certain walls.  I noticed that the walls that I split, the decal will not work on it.
Wed, Jul 20, 2011 at 11:07:38 AM | Decals not Rendering in 2010/12
ChChChChela
ChChChChela Avatar
I made a family that is a picture frame that attaches to the wall and I put the decal on that instead.  Works perfectly :-).  Thanks again.
Wed, Jul 20, 2011 at 1:34:53 PM | Decals not Rendering in 2010/12
Yes, you found that the decal needs a host.  When you split the wall, the decal could not host across the split.  Glad you sloved your problem.
problem with rendering decals
Mon, May 14, 2007 at 5:44:57 PM
problem rendering decals
Tue, Aug 3, 2010 at 8:18:16 AM
Rendering Decals
Fri, May 8, 2009 at 11:45:11 AM
Decals not showing..
Fri, Feb 16, 2018 at 9:39:04 AM
12
Decals not rendering
Wed, Aug 17, 2011 at 11:00:09 AM
Page generation time: 1.0796
