20 Users Online (19 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Tips & Tricks >> REVIT 2009
Fri, Jul 15, 2011 at 12:46:41 PM | REVIT 2009
tmassey
tmassey Avatar
hi all..is there a way to change or revise text thoughout the entire project. e.g. struct'l to structural?
cheers
Using Revit Architecture 2012
Fri, Jul 15, 2011 at 1:18:07 PM | REVIT 2009
AbsoluteBIM
AbsoluteBIM Avatar
4 Stars: 4 Votes
hit the big 'A' ontop to open the edit text options and use 'find and replace' as shown in the attached image.
Fri, Jul 15, 2011 at 1:36:18 PM | REVIT 2009
tmassey
tmassey Avatar
thank you but Revit 2009 does not have the big A..where else would I find this?
Fri, Jul 15, 2011 at 1:41:13 PM | REVIT 2009
AbsoluteBIM
AbsoluteBIM Avatar
4 Stars: 4 Votes
I've never used 2009 but however you would normally start a text or leader command. just look up for find and replace but I can't be certain. sorry
Fri, Jul 15, 2011 at 1:59:44 PM | REVIT 2009
tmassey
tmassey Avatar
cheers
Revit MEP 2009 family to be used in Revit Architecture 2009
Fri, Feb 6, 2009 at 8:09:24 AM
Export Mass from Revit 2009 to 3ds Max 2009
Tue, Feb 16, 2010 at 9:13:53 AM
Does anyone have Revit 2009, yet [ 1 2 ]
Thu, May 8, 2008 at 8:09:52 AM
23
Rendering in Revit 2009 [ 1 2 ]
Thu, Dec 31, 2009 at 10:41:31 AM
19
I need to open a Revit 2011 file into the Revit 2009 ? Are there any way ? [ 1 2 ]
Thu, Jan 6, 2011 at 3:25:02 PM
18
Page generation time: 1.3509
