115 Users Online (114 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Topography won't generate off points
Thu, Jul 14, 2011 at 4:42:44 PM | Topography won't generate off points
MYoung
MYoung Avatar
Revit 2011
Hi, I cannot get revit to create topography off an imported (not linked) survey AutoCAD file.  I'm only importing the points.  When I do this, when queried, revit calls it a 'block instance', and when I try and create the surface, I select imported instance, select the Cad file, and finish the sketch.  No topography appears.
I'm experienced with Revit, but don't use imported instance files much, meaning I've troubleshooted all the obvious things first, to no avail, like VG, crop region, scope boxes etc.  I can't figure out why Revit thinks the CAD points are a block, when they're not.
Any ideas? Thanks.
Fri, Jul 15, 2011 at 1:18:16 PM | Topography won't generate off points
itsmyalterego
itsmyalterego Avatar
4 Stars: 16 Votes
I've had by far the best luck using civil cad with 3D topo lines.  I don't know if this is included in your dwg as a layer or not.
Fri, Jul 15, 2011 at 6:30:02 PM | Topography won't generate off points
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
First read your help files.
What I do, is go to Site Plan then click on insert/Import CAD then you navigate to the CAD file you wish to import and it will appear in the window, finish that.
Then, go to Massing&Site, click Toposurface/Create from Import/Select import Instance, Select the CAD topo in your Site window. When you do that a window will come up with essentially the layers that were imported. Generally I turn off all layers, then turn on only the Contours Major and the Contours Minor. Then finish. I suppose it depends on the survey and software that has been used to create the ACAD drawing, this is what seems to work for me.
Hope this helps
Mon, Aug 21, 2017 at 7:34:47 AM | Topography won't generate off points
ZorroCRO
Yes, but for some reason Revit won't use ACAD points to create toposurface. It still create it from contour lines, but it ignores points between.
I think it is a new problem. If I remember correctly, Revit recognized ACAD points in linked files before.
Mon, Aug 21, 2017 at 10:14:34 AM | Topography won't generate off points
3.5 Stars: 395 Votes
Make sure you tell Revit all of the layers it should use.   Usually independent points are not on the contour layers.
Mon, Aug 21, 2017 at 4:25:40 PM | Topography won't generate off points
ZorroCRO
I told Revit which layer to use. I created that layer and points on it.
It just dont recognize it.
Fri, Oct 27, 2017 at 3:59:37 AM | Topography won't generate off points
Marijanmar
I had same problem, but you can work this around
1. Try to export your points (x,y,z coordinates) from dwg with this "PLIST.lsp script"  http://cadtips.cadalyst.com/points/export-pointcoordinates
2. In Revit insert points via "Create from Import" -> "Specify Points File"  (.txt)
Fri, Oct 27, 2017 at 5:09:56 AM | Topography won't generate off points
Beaucoupnice
Beaucoupnice Avatar
3.5 Stars: 6 Votes
Another link explaining a work around that requires you to go to each point in autocad and draw a circle. Then import DWG to revit.
http://forums.augi.com/archive/index.php/t-121308.html
Curved monolitic stair won't generate in 3d
Tue, Mar 6, 2012 at 8:52:04 AM
Topography points Crash in Revit 2013
Wed, Oct 31, 2012 at 4:34:47 AM
Topography won't snap back into place
Tue, Nov 11, 2008 at 8:38:42 AM
Topography Quality [ 1 2 ]
Mon, Sep 21, 2020 at 7:51:10 AM
17
property lines hidden by topography
Tue, Mar 6, 2007 at 11:47:47 AM
Page generation time: 0.6177
