54 Users Online (52 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Creating a timber sprocket
Thu, Jul 14, 2011 at 10:55:41 AM | Creating a timber sprocket
rickzloureiro
Hi Guys,
Im creating a flat timber roof and want to give it a slope of about 3 degrees, we normally install a sproket above square flat roof deck which gives it the slope, i am having troubles however trying to illustrate this in revit. The timber sprocket is 38mm wide x  5m long and on one end is 50mm high and on the other end its basically 1mm so it tapers from 50mm to pritty much nothing.
I hope i have explained myself correctly and would appreciate your help.
Thanks
Ricky
Thu, Jul 14, 2011 at 12:07:15 PM | Creating a timber sprocket
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
Not quite sure of the terminology of "sproket", believe here in the US it would be considered a cricket. This could be accomplished by creating a secondary floor, with a flexible thickness below the plywood then this secondary floor can be adjusted to slope as needed.
Thu, Jul 14, 2011 at 12:35:38 PM | Creating a timber sprocket
I would not use a floor.  My cricket is a face base family, roof category that is parametric so I can adjust its size.
Timber Framing
Tue, May 9, 2006 at 9:04:39 AM
Timber curtain wall system
Wed, May 8, 2013 at 7:40:34 AM
timber gable finials
Tue, Jun 26, 2012 at 11:02:02 AM
How would I go about creating a timber frame?
Fri, Feb 10, 2006 at 3:49:50 PM
Complex Timber Column (assistance needed)
Mon, Aug 29, 2016 at 3:28:58 PM
Page generation time: 0.9822
