58 Users Online (57 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Centerlines
Thu, Jul 14, 2011 at 9:52:05 AM | Centerlines
Volorgas
I am using compound walls throughout my project and the exterior walls are configured such that the wall centerline is 3/16" outside of the core centerline.  This is causing some difficulty and confusion as the walls are located using the core centerline but Revit seems to use the wall centerline for everything else, thereafter.  I would like to use the core centerline for everything (layout, orientation, dimensions, etc.) and not use the wall centerline for anything.  Is it possible to disable or turn off the use of the wall centerline, or perhaps I can specify to Revit that the core centerline is to be used for all references, instead of the wall centerline?  Any help will be greatly appreciated.  Thanks.
Thu, Jul 14, 2011 at 9:55:41 AM | Centerlines
Volorgas
Sorry, forgot to mention that I am using Revit 2011.
Thu, Jul 14, 2011 at 10:43:26 AM | Centerlines
Revit doesn't "use the wall centerline for everything", it just starts there.  Use the tab key to toggle dimension reference locations.
Be careful with stacked walls if that's what you mean by "compound" as they are actually individual wall types that are stacked and they will dimension differently depending on where you are in the stack.
Thu, Jul 14, 2011 at 12:01:09 PM | Centerlines
Volorgas
I believe what was happening was that the compound walls were placed or "located" using the core centerlines, but then, the temporary dimensions associated with them were set to use the wall centerlines, and this caused the inconsistency.  Setting Revit to use core centerlines, in lieu of wall centerlines, for the temporary dimensions, resolved the issue.
pipe centerlines
Mon, May 11, 2015 at 7:07:46 AM
How to turn off pipe centerlines in Revit MEP 2013?
Mon, Nov 26, 2012 at 12:07:40 AM
centerlines and insulation
Wed, May 6, 2015 at 2:49:06 PM
Temporary Dimensions and Wall centerlines
Thu, Oct 20, 2011 at 1:31:21 PM
MEP Piping Question
Wed, Jul 20, 2011 at 4:28:05 PM
Page generation time: 1.1917
