83 Users Online (82 Members):
Forums >> Revit Building >> Technical Support >> Constant saving everytime I make a move...pan
![ORIJAN Avatar](user_avatar/186915.jpg)
1 Posts No Rating |
Why does Revit 2012 save everytime I make a move or pan ....the save circle pops up and and I have to wait for a minit or two
----------------------------------- JET BLACK |
Are you on a network, if so, where is your file saved?
Are you in a work-shared file?
What is your system? 32 or 64 bit? How much memory?
4 Posts No Rating |
I am having the same issue today. (Jul 14)
Basically, every time a Revit machine moves/pans/extends/drags they lock up and take 15 seconds to execute the command.
Work-shared working off local in My documents
Windows 7 - i7 2.93 Ghz w/ 8 GB RAM
Revit 2012 - 64 bit
![brettgoodchild Avatar](user_avatar/14257.jpg)
![4 Stars: 17 Votes](/images/stars_4.gif) |
Can't say that I have ever seen Revit Sync w/o being told to do so.
You can check this by pulling up the files history and if it is infact syncing you may want to pass it on to supprt and see what the issue is.
If you watching the status line and it is stating the CF is being accessed, that is because the LF and CF are constantly communicating through the database record lock and it is hanging on the network for some reason.
Might also be helpful to do a jing recording and post it for people to see the issue.
Fixed or Constant Area |
Sat, Mar 28, 2009 at 4:18:54 PM
steel pan visibility in 3D view ? |
Sun, Jun 4, 2017 at 1:49:03 PM
pan views |
Fri, Jun 25, 2004 at 3:56:50 PM
Dimensioning a Sloping Concrete Pan Joist Roof |
Sat, Feb 14, 2009 at 11:07:40 AM
temporary dimensions require me to pan to see them |
Sat, Mar 26, 2016 at 9:52:41 AM
Members: | 2022302 | Objects: | 22973 | Forum Posts: | 152200 | Job Listings: | 3 |
