59 Users Online (58 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Systems >> Technical Support >> mullion issue
Wed, Jul 13, 2011 at 12:16:17 PM | mullion issue
timmyd2283
hello>> good morning to all >> id like to ask some question on this one>> its actually concerning a sloped glazing issue.. i tried to use the material as a trellis>> now earlier i did some research but now the issue is how can i change the mullion material, id like to change it to wood so that it will look more like a trellis rather than just a simple mullion frame. any possible solution to this>. because when i opened the type properties, the only thing i can see are the number of mullions, etc!! cant see any material where i can change it..pictures attached so at least you can visualise what the issue is> and nevermind the rendering, its in draft settings>> again thanks alot!!! :-)
Wed, Jul 13, 2011 at 12:24:01 PM | mullion issue
The mullion material is set in the mullion properties.  Find the mullion type in your browser and change the material there.
Wed, Jul 13, 2011 at 1:07:49 PM | mullion issue
timmyd2283
hmmm>> thanks a bunch>> didnt figure that out earlier>> again thanks!!! :-)
mullion ang transom not fitting well [ 1 2 ]
Wed, Oct 9, 2013 at 11:42:10 PM
23
Curtain Mullion eats into vert mullion
Thu, Jan 22, 2015 at 4:49:08 PM
mullion join at angled mullion 2017
Sat, Oct 21, 2017 at 11:53:54 AM
Curtainwall door mullion/jamb issue - door is wider than inside mullion spacing
Mon, Jan 19, 2015 at 7:41:36 AM
coneptual massing curtainwall mullion issue
Thu, Nov 5, 2009 at 11:54:41 AM
Page generation time: 0.7777
