46 Users Online (45 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> families properties grayed out
Wed, Jul 13, 2011 at 7:15:18 AM | families properties grayed out
SteveB
3.5 Stars: 5 Votes
On a family like the the "outlet floor - single" electrical fixture, a stock revit symbol, can the properties "Electrical - Loads" be modified?  Their fields are grayed out.  See attached.  I tried to edit the family but couldn't find those properties in the family.
Wed, Jul 13, 2011 at 7:23:45 AM | families properties grayed out
Did you click on "EDIT TYPE"
Wed, Jul 13, 2011 at 7:31:52 AM | families properties grayed out
SteveB
3.5 Stars: 5 Votes
yes - those fields don't appear there
Wed, Jul 13, 2011 at 7:55:50 AM | families properties grayed out
These are type variables and may be locked in the family, so then edit the family.
You have this under the Revit Building category but my floor outlets do not have these parameters.  Are you sure this is not a MEP family?  As such, these values will be used in your systems so know what you are doing.
Thu, Jul 21, 2011 at 9:38:19 AM | families properties grayed out
SteveB
3.5 Stars: 5 Votes
it is true of EVERY lighting fixture in the entire project.  both parameters (panel and circuit#) under "Elecrical Loads" in the properties box.  Modifying one family wouldn't help
Thu, Jul 21, 2011 at 9:42:44 AM | families properties grayed out
SteveB
3.5 Stars: 5 Votes
if you try to enter info in those fields in a schedule, it cannot be done.  The seem to be locked somehow.
Thu, Jul 21, 2011 at 1:13:21 PM | families properties grayed out
SteveB
3.5 Stars: 5 Votes
My solution:  define a new field and ignore it.
Switch ID Grayed out in Revit MEP
Tue, Feb 26, 2013 at 11:33:36 AM
Properties to TYPE Properties
Tue, Dec 19, 2017 at 2:01:31 PM
Thumbnails of families in properties browser
Tue, Jan 7, 2014 at 7:54:37 AM
Render button grayed out
Sat, Jun 30, 2012 at 2:16:34 PM
Sloped roof surface pattern grayed.....Revit 2015
Thu, Jan 15, 2015 at 1:48:15 PM
Page generation time: 0.9150
