61 Users Online (60 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> linking dwg files in elevations
Wed, Nov 23, 2005 at 11:53:37 AM | linking dwg files in elevations
Will9000
4 Stars: 5 Votes
Can you link a dwg file in elevation? it wont let me for some reason, any guidance be much appreciated,
Wed, Nov 23, 2005 at 3:04:33 PM | RE: linking dwg files in elevations
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
I'm having no problems here doing that. Make sure you have current view only ticked, otherwise you'll need a workplane set in elevation in order to place the import on.
Problems linking DWG CAD files into Revit
Wed, May 14, 2014 at 10:33:53 AM
Linking Revit Files for Sheet Coordination
Fri, Jul 10, 2009 at 11:09:10 AM
DWG linking into revit
Mon, Jun 9, 2014 at 7:11:39 AM
Problem Linking DWG Files Showing Rebar as Polyline
Tue, Jan 22, 2008 at 11:07:57 AM
Looking For Easy Way to Control Lineweights When Linking DWG Files
Fri, Jan 18, 2008 at 3:17:59 PM
Page generation time: 0.5220
