72 Users Online (70 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Door families not flexing with layered walls
Tue, Jul 12, 2011 at 9:06:02 PM | Door families not flexing with layered walls
tfcheer96
While trying to create door families for a project I have had a repetitive problem when the wrap around jamb trim does flex to the outer skin of a layered wall system. I can fix this by adding an extra "instance offset" for each face, but this is an extra step I shouldnt have to take. the building model represents a 100 year old brick masonry structure with varying layers of plaster parging.
the solid brick walls of the model are full height from basement to the third story roof, with varying thickness "layer" finish walls joined to the brick core.
Wouldn't all this be solved if I copied all the walls from on floor to another, and edited each wall occurrence to provide the actual thicknesses needed? when is it better to copy floors verse running them full height.
Wed, Jul 13, 2011 at 6:50:32 AM | Door families not flexing with layered walls
3.5 Stars: 400 Votes
If your wall is not one wall but actually multiple, joined walls, then you can not expect your door family to know thiis.  It is hosted by one wall and everting is based on that wall.  You will have to add a jamb thickness variable or handle with a seperate family.
If you had built these walls as most of us do using multiple types (one for each different thickness), you should not have this problem.
Edited on: Wed, Jul 13, 2011 at 6:52:06 AM
Can Door/Window cut through multiple walls
Fri, Jun 1, 2012 at 1:45:26 PM
Foundation Wall with Brick shelf (Layered)
Fri, Jul 29, 2011 at 11:33:00 AM
adjustable double door
Tue, Mar 27, 2007 at 10:23:28 AM
Door Families and Profiles
Thu, Apr 22, 2010 at 1:06:47 PM
Door Families with HM frames that center on walls.
Thu, Sep 21, 2006 at 9:15:16 AM
Page generation time: 0.9621
